1.9.2 - HEIC metadata is not displayed, but exits
pel9
Post by pel9 »
Hi
the meta data is displayed for the raw file in the Browser:
Screenshot 2025-07-07 162729.png (111.83 KiB) Viewed 1243 times
For all the HEIC files, it is not displayed:
Screenshot 2025-07-07 162651.png (94.16 KiB) Viewed 1243 times
But it exists(from the Info panel, properties for the HEIC file):
Screenshot 2025-07-07 162705.png (11.6 KiB) Viewed 1243 times
If you need sample HEIC file:
https://ibb.co/tPh70mdS
Re: 1.9.2 - HEIC metadata is not displayed, but exits
could you send us the heic not the jpeg file?
pel9
Post by pel9 »
https://www.file-upload.net/en/download ... .HEIC.html
the image platform ibbo transformed it into jpg
This problem is supposed to be fixed in XnView MP 1.9.3. Please check and confirm the bug fix here.
pel9
Post by pel9 »
xnview wrote: Mon Aug 11, 2025 6:08 am This problem is supposed to be fixed in XnView MP 1.9.3. Please check and confirm the bug fix here.
can confirm fix. Thanks a lot for your work.
