1.9.2 – New folder bug
Kadet
Post by Kadet »
Windows 11 Pro
I have a strange bug on one computer, but not on the second (Win11 Home).
When I click add new folder [F7] and start to type name this new folder, after few chars it is clear and will back text "Nowy folder" ("New folder") :shock:
Bug on video:
XnView New folder bug.mp4
My ini file:
xnview-ini.zip
Re: 1.9.2 – New folder bug
even if you wait some seconds?
Kadet
Post by Kadet »
When I wait a few seconds, the blue background of the marked text disappears and the cursor appears at the end of the inscription. Then I can delete the test and give my name to the folder.
when you click new folder, the slider at the bottom for thumbnails is working?
Kadet
Post by Kadet »
xnview wrote: Sat Aug 02, 2025 12:56 pm when you click new folder, the slider at the bottom for thumbnails is working?
After pressing F7, the thumbnails slider at the bottom works. The slider works no matter what I do, i.e. when I start writing, and when I use the slider immediately, and when I wait until the cursor appears at the end of the "New Folder" text.
