When I have the app open to a narrow window-width (on a crowded monitor
entry shows little of the pathname.C:\moun...2\DCIM\
I have a few external disks mounted under a common mount-point, e.g.
C:\mount\disk1
C:\mount\disk2
When I'm trying to go back to a previous folder using the History pull-down, it's often not clear which folder is which in the pull-down list.
The suggestion: Please, if a tooltip could be displayed when the mouse is sitting over a row in the pull-down list, showing the full pathname of the row the mouse is over.
Thanks!
Michael
