Save lists are different and have bugs
Olivier_G
Post by Olivier_G »
In Batch convert (and Acquire into), the 'save list' has separator.
In File>'Save as' from View, the 'save list' has no separator.
=> 'Save as' should have a separator.
When you select separator, the format just above is chosen, which is not good.
=> It would be better NOT to change selected filetype at all...
When you extend the 'save list' it is scrolled down in order to start from selected filetype.
=>It would be better to start from top (ie: not scrolled at all) since the user chosed his preferred formats on top.
Olivier
XnView 1.82
Dreamer
Post by Dreamer »
