Is the "Parameters" field ignored in the "Configure programs" dialog?
laurent45654
Post by laurent45654 »
I'm on macOS and I'm trying to run an app from XnView MP via the "Configure programs" dialog. I want to pass some argument first, then the name of the file. However, whatever I put in the "Parameters" field is not being passed to the app. All I can see is that the first argument is the image file path, but my own custom argument is not there.
Any idea what might be the issue?
Also is there any documentation for this feature?
laurent45654
Re: Is the "Parameters" field ignored in the "Configure programs" dialog?
Any ideas?
currently parameter on Mac is ignored
laurent45654
Thanks, at least I know I don't need to do more tests with this. Is there any plan to add support for this?
This "Configure programs" feature could be very powerful to customise the app with custom workflows so it's a pity it's a bit limited. For example native support for shell scripts would be brilliant since we could just pass the image path and custom parameters and run all kind of image processing scripts.
Now what I do is create a custom app using Automator that calls a Bash script. But I need to do this for each script, and for each combination of parameters, which is cumbersome.
ok, i'll check to support it
laurent45654
Oh wow, that would be brilliant, thank you for considering it 🙏
