Quick links
Troken
Quick links
Post by Troken »
A great feature would be a row of quick links to folders that you use a lot. At work, we use FotoStation and it is great to have our own folders, just a mouse-klick away. That means you do not have to search in the folder tree for you often used folders. Very much like favorites/links in a webbrowser.
ckit
Post by ckit »
I know what you mean, it's a IE feature and would require another mini-toolbar in XnView.
One problem, none of the toolbars in XnView are dockable so it's a no go at the moment.
You'll have to live with the Favourites menu.
Troken
Post by Troken »
Can't belive that I haven't tried out the "favorites-menu" before, it's excellent. I'm happy now! (This program is really something!)
Dreamer
Post by Dreamer »
Troken wrote:Can't belive that I haven't tried out the "favorites-menu" before, it's excellent. I'm happy now! (This program is really something!)
There are also shortcuts - F6 and Ctrl+F1.
Troken
Post by Troken »
OK, thanks. I'll try to use them. Guess its all in the help.
Dreamer
Post by Dreamer »
Troken wrote:OK, thanks. I'll try to use them. Guess its all in the help.
Not yet, but here.
