When using XnConvert in Japanese on Windows 11, the numbers are garbled.
Even when using the latest version of XnConvert, the garbling still occurs.
Please check the image I sent.
I would appreciate it if you could fix this issue.
Thank you in advance.
take
Re: When using XnConvert in Japanese on Windows 11, the numbers are garbled.
Only width/height columns? I can't reproduce by using japanese in 1.105 version
take
Thank you for your reply.
In both Version 1.95 and the latest 1.105.0,
the width and height numbers are garbled.
if you use english language, same problem?
take
I changed the language to English.
The characters are still garbled in English.
relally strange, only width/height or any numeric value?
Probably showing my ignorance, could this possibly be a code page issue?
take
I'm not familiar with computers, so I'm not familiar with computers,
What is your 'system locale' in 'Language for non-Unicode programs'?
(Windows Settings > Time&Language > Language&Region > Administrative language settings) video
Try changing it to Japanese
take
I checked the language settings.
Everything is set to Japanese.
Based on the advice I have received so far,
it may be a problem specific to my computer environment.
