Hello, I’d been a long time XnView Classic user and recently I’ve decided to move to the MP version just because of an occasional unicode character in my file names, so that I’d no longer be forced to rename those.
I’m here to report that I’ve found a weird behaviour in the menu – Image – Adjust – Enhance colors (accessible by pressing Shift+E in both versions of the viewer), I occasionally use it to adjust colours and while in the Classic version you can increase or decrease the value of any of the R/G/B colours by as little as 4 points on that scale and immediately see the difference, that seems to do nearly nothing in the MP version, the slider has to be moved like 70 points on the same scale to be able to start noticing a difference, there must be something wrong, I guess.
Image - Adjust - Enhance colors (Shift+E)
