1.9.2: "OR" not working in catalog filter
dchristensen
Post by dchristensen »
In the catalog filter, if I use Control-click to select "Excellent" and "Important", and use the "Match" drop down to select "Match any selected entry (OR)", I still only see the images that are marked with both Excellent and Important. I get the same results if I switch to "Match all selected entries (AND)".
To reproduce: open a folder with at least three images. Mark the first as Important, the second as Excellent and the third with both. Make the catalog selections above. I would expect to see all three photos, but I see just the third one.
Re: 1.9.2: "OR" not working in catalog filter
This problem is supposed to be fixed in XnView MP 1.9.3. Please check and confirm the bug fix here.
dchristensen
I confirm that it works correctly now. Thanks!
