1.9.2: Large file size displayed incorrectly in status bar
Mapaler
Post by Mapaler »
Issue 1
XnView: MP 1.9.2 - 64 bit
OS: Microsoft Windows [Version 10.0.19045.6159] - 64 bit
When opening a file with an extremely large size, the file size displayed in the status bar is incorrect.
Effect: Digital display error.
  1. Download eso1242a.psb 24.6 GB (26,455,654,863 Byte) at https://www.eso.org/public/images/eso1242a/
  2. Open eso1242a.psb by XnViewMP.
  3. Observe the file size displayed in the status bar.
Actual behaviour (bug): The status bar shows an incorrect or incomplete file size 654.77 MB. :bug:
Expected behaviour: The status bar should display the correct file size 24.6 GB.
Issue 2
When opening a specific file, the default anti-aliasing feature causes significant lag during operations like fitting the image to window size. Even minor adjustments to the window size result in the program becoming unresponsive.
Suggestion:
Automatically disable anti-aliasing for files exceeding a certain pixel threshold to improve responsiveness.
Implement a pre-rendered intermediate-sized cache (or downscaled preview) for smoother interactions with large files.
This would enhance the user experience by reducing delays during window resizing or zooming operations for high-resolution files.
Re: 1.9.2: Large file size displayed incorrectly in status bar
Mapaler wrote: Tue Jul 29, 2025 7:46 pm Automatically disable anti-aliasing for files exceeding a certain pixel threshold to improve responsiveness.
such things should be implemented via modal popups, not via automatic "magic behaviour"
(if bother at all, as opening huge files is not a common task and user should be aware of what he is doing in the first place)
Mapaler wrote: Tue Jul 29, 2025 7:46 pm Issue 1
This problem is supposed to be fixed in XnView MP 1.9.3. Please check and confirm the bug fix here.
