ver 1.9.2 Bug: Dragging images in browser and slideshow window will sometimes create duplicate files
Toby W.
Post by Toby W. »
Sporadically, when dragging thumbnails in the browser and or the slideshow browser widow, XnViewMP will create duplicates of the dragged image with the string _Copy appended to the filename. This is weirdly inconsistent. I have verified that copies on the source directory are indeed created and these are no ghosts or aliases. Also the modification date is not affected in the process.
I have been able to replicate, then it behaves normally, in the same directory – weird
Toby W.
Re: ver 1.9.2 Bug: Dragging images in browser and slideshow window will sometimes create duplicate files
if you drag a thumbnail, in browser you can create a copy. In slideshow, you duplicate this image
