1.9.2 Mac: Keyboard controls in dialog boxes not working
XnSoldier
Not working at all it seems. I tried single key, with CTRL, Option, Command or FN to no avail.
Photographer. Sorting 100.000-250.000 pics per year
20 years with ACDSee Photo Professional. Love and Hate. I would love to see XnView MP upgraded for better editing or a commercial "XnPhoto Pro"! Keep up the great work!
Re: 1.9.2 Mac: Keyboard controls in dialog boxes not working
how do you have button shortcuts, i dont have them on MacOS 15.5
XnSoldier
we hit keys on the keyboard
mostly, there is a default button which can be activated by hitting enter. Or moving focus on buttons with arrow keys. Or use ESC for canceling.
I can't recall any software now that has keyboard combinations for buttons like CMD-C or so.
Mac keyboards have Shift, Control, Option and Command keys which can be used in combination with "real" keys.
no sorry but i means that 'Convert' has underline on the C, but i dont have that on MacOS 15
XnSoldier
Oh, strange, I have no idea. I always had them with XnViewMP on my System. Latest MacOS. But it would be great to have basic keyboard control of buttons (enter, esc).xnview wrote: Wed Aug 06, 2025 2:10 pm no sorry but i means that 'Convert' has underline on the C, but i dont have that on MacOS 15
do you use default theme?
XnSoldier
Theme Dark.
yeah. With Default Theme I don't have the underlined Letters anymore.
its the normal behavior on MacOSXnSoldier wrote: Thu Aug 07, 2025 12:15 pm yeah. With Default Theme I don't have the underlined Letters anymore.
XnSoldier
Still irritating if with dark theme keyboard shortcuts are suggested but not working
btw: menu item shows "explorer" to open files on desktop. but it is called finder on MacOS. Maybe just say "Open on desktop". I would really add "Open in" as it is unclear what "explorer" actually does. Especially on a Mac
Where? i use 'open in Finder'XnSoldier wrote: Thu Aug 07, 2025 4:35 pm btw: menu item shows "explorer" to open files on desktop. but it is called finder on MacOS. Maybe just say "Open on desktop". I would really add "Open in" as it is unclear what "explorer" actually does. Especially on a Mac![]()
XnSoldier
Folder list. There it says "Explorer"
XnSoldier
Right, 'Explorer'. So 'Open in explorer' or 'open in Finder'?
[/quote]
Open in Finder on MacOS since there is no "Explorer" as mentioned earlier.
its better to use 'Show in file manager' universal name for this command, which:
- suits any OS (File explorer in win, Finder in Mac, etc)
- uses correct term, show instead of open (app opens file manager and only selects file)
XnSoldier
good suggestion user0. thanks
