Crash when deleting file in comparison view
jkm
Post by jkm »
XnViewMP 1.9.2 crashes when deleting a file in comparison view.
Steps to reproduce:
1. Select 3 files in the browser.
2. Click the Compare button on the toolbar to compare
3. Select Tabs as the comparison view
4. Activate the tab for the 2nd of the three files
5. Click the delete button on the toolbar.
6. When you get the msgbox "Do you want to delete this file?" click Yes.
Crash.
The file does get deleted, however.
jkm
Re: Crash when deleting file in comparison view
Post by jkm »
Apologies, I didn't see the other one.
i can't reproduce, could you send me sample files to reproduce?
jkm
Post by jkm »
That is very surprising. It happens with any files, and it happens with a fresh, untouched XnViewMP v1.9.2
Suggest you try the following:
1. Download a fresh copy of XnViewMP x64 portable/zip
2. Unzip and run
3. For the startup wizard, select:
Language=Autodetect
Theme=Default
Settings=Portable
Add Browse with XnViewMP UNchecked
Check for Program Updates=Never
Now download any three test jpegs from this site and put them in a folder:
https://www.sample-videos.com/download- ... -image.php
Browse to that folder in the app and follow the steps in my previous post. XnViewMP will crash.
This was running on Windows7x64.
Please note: It does NOT crash if you use NORMAL view in the Comparator. It only crashes if you select TABS as the comparison view.
jkm
Post by jkm »
I'm glad you were able to reproduce it.
Sorry to make more work for you, but thank you for fixing it. :)
This problem is supposed to be fixed in XnView MP 1.9.3. Please check and confirm the bug fix here.
jkm
Post by jkm »
Yes, it is fixed. Thank you!
