Open on Primary Screen
Rich-J
Post by Rich-J »
XnView MP, current version. Win 11 Current version. nVidea GPU current Studio driver.
2 monitors -1 = 4k BenQ: 2 = 1080p LG.
In the past I could move XnView between monitors and Full screen opened on the other monitor.
Now it always opens "full size" (not full screen) on monitor 2 and cant be moved (can't resize or drag it). Full Screen also opens on Monitor 2 (irrespective of setting for Dual Screen).
I don't see any option to define which screen it opens on or to set size on opening (ie to less than screen width).
Any suggestions?
Richard
Rich-J
Re: Open on Primary Screen
Post by Rich-J »
Additional info:
I renamed the .ini file. It then opens as a resizable window on monitor 1 (after a brief "startup settings" window is displayed). This suggests to me a problem in the ini file.
I can not find documentation on the ini file on the website.
Looking at it and guessing...
This, near the top of the [Start] section might be incorrect:
startupType=1
startInFull=0
Or, in the [Browser] section
size=@Size(1920 1049)
This is the screen size for monitor 2 (actually 1920x1080), monitor 1 is 3840 x 2160.
Any ideas?
Richard
with a clean .ini, you have no more the problem?
Rich-J
Post by Rich-J »
It opens in Browser mode on Monitor 1 but all settings are lost. It does not create a new ini file in the program folder.
The issue is that it always opens in browser mode on monitor 2 and the window is not resizable or movable.
Richard
Rich-J
Post by Rich-J »
I copied the ini file from another dual monitor machine that operates correctly...
It now works as expected and did previously.
Opens on whichever monitor it was closed on, and is resizable.
Lack of documentation is a problem...
Richa
