1.9.2 Move companion files doesn't work from viewer
HarryHengst
Post by HarryHengst »
For me, a unique features of XnView MP is the option for Companion Files. I use it to only show .JPG files in the browser and hide the corresponding RAW (.ARW) files. I observe unexpected behavior when I try to move a file. I have the "Link companion files for the following actions: delete, copy/move/rename" enabled.
When I am in the file browser mode and select Move (Alt+M), the .JPG is moved together with the .ARW RAW file. This is the expected behavior. However, when I am in the viewing mode and I select select the same Move option (again via Alt+M), only the .JPG is moved and the .ARW files stays. I would expect that in both cases, the .ARW file would be moved together with the .JPG file.
Re: 1.9.2 Move companion files doesn't work from viewer
:bugconfirmed:
