Hi there,
is it possible to define own layout presets in the printing dialog?
Markus
Own layout presets in printing dialog?
Re: Own layout presets in printing dialog?
Add support for printing as a matrix MxN, within defined borders and with the space between images defined, or something else?
Margeb
Sorry but you lost me after the "Add"
Markus
Markus
I was assuming, after a quick look at the present Print interface, that there is currently no support for user layout presets.
After looking more closely at the Print interface, I see that there is current support for setting a personal layout, although I don't see a way to save a defined layout for possible future reuse. So you were asking whether there is currently a way to remember previously-used layouts: I don't see one. Apologies for complicating the issue.
Margeb
No problem cday,
sorry for the misunderstanding!
Markus
Markus
If you feel that a way to select previously used print settings would be useful, you can make that request in the MP - Suggestions forum heading.
