1.9.3 Installer checkbox for custom and Full install is broken
I don't know if previous versions are affected, but I recognized, that if I click on the checkbox for the one optional feature to install, then the dropdownlist for Full install vs. custom install does not change accordingly. So if one toggles the checkbox also the dropdownlist, then full install is without the one feature and also exact the opposite.
Let me know if you need more information and/or I failed trying to explain the behavior
Thank you
1.9.3 Installer checkbox for Custom and Full install is broken
Klaus1189
