File operations - backups - add versioning
XnViewMP 1.9.3
new backup overwrites existing one with the same file name (name.xnbak.ext),
so the original image will be lost if several changes are made consecutively
  • add versioning
    create a new separate backup after each iteration
    • naming
      - add timestamp to filename (eg name.xnbak.YYYYMMDD-HHMMSS.ext)
        OR
      - follow 'duplicate naming' setting (in Settings>File operations>Copy group)
    • (optional) focus
      - shift focus after each action to use edited file as current, instead of original
Related
