Is there a setting I can change to make all images open at 100% size by default?
Also, is there a button I can add to the toolbar that will toggle between best fit and 100%, or what is the best way to deal with this?
Thank you for any help,
Cheers, Marty
default view 100%?
Yes… NO !
- If you use the option “View” >>Auto image size >> "No fit", the pictures are opened as 1:1 scale.
- Moreover, you can get the 1:1 scale simply pressing the NUM “*” key at every moment,
while the “ / ” NUM key (re)sets "Fit to window"…
Also, is there a button I can add to the toolbar…
camelgrass
Re: default view 100%
Hi, and thanks for your reply
It's useful to know those keyboard shortcuts, thanks.
This setting I know about “View” >>Auto image size >> "No fit". But when closing and reopening XnView it does not save this setting.
Cheers,
Marty
Cheers,
Marty
Fresh INI…
- It should do ! I checked this just now, that works here, that setting is saved alright, as well with the current version 1.80.3, as with the 1.82 RC2 on tests currently. Under XP-Pro SP1This setting I know about “View” >>Auto image size >> "No fit". But when closing and reopening XnView it does not save this setting.
- You could try to rename your XnView INI file, then the programme'll rebuild a fresh one, and let's know what occured
- Inconvenience : if that works properly such as, you'll be bound to remake your settings…
ckit
camelgrass
Hmm... strange.
It still doesn't want to stay on that setting. It always wants to go back to "Fit image to window, large only", regardless of what size or type the image is.
I tried renaming the xnview.ini but it didn't make any difference.
Also, I unchecked the box in options that says "No thumbnail for PDF/PS/AI files". Should I be seeing a thumbnail image of PDF files now? I don't.
Thanks for your help, Marty.
The right INI?
- “Are you sure”
- Please, check "Options" >> Installation to see which option-saving is set.
- Maybe have you an old INI in the <windows> dir, and it's used…?
- Or else, the settings are saved in the Win Register, or so… ?
- To get the use of the INI located in the XnView folder, the couple of lower tick-boxes must be both not ticked !
camelgrass
Re: The right INI?
hi Claude,
Yes, XnView is definitely using the right INI because it was replaced when I renamed it. Both options are unchecked as you indicated they should be.
I'm a new user to XnView, I just installed version 1.80.3 recently. I may try reinstalling it later on.
By the way, I found the "Zoom 100%" button that I was looking to add to the Toolbar!!
Also, should PDF files show a thumbnail image using the settings from my previous post?
Cheers, Marty
Cheers, Marty
Olivier_G
Are you talking about the main Options window > View > Auto image size (as Clo) which should keep settings or about the Menu>View>Auto image size (which is a temporary setting) ?camelgrass wrote:This setting I know about “View” >>Auto image size >> "No fit". But when closing and reopening XnView it does not save this setting.
About PDF, check this: http://newsgroup.xnview.com/viewtopic.php?t=1228
Olivier
