Issue when displaying manga images
Arth
Post by Arth »
For some reason XnView adds this entire white background like it's the part of the image and the pages become small in fullscreen view. Acrobat Reader has no such issues and displays everything properly. Both images takes when in fullscreen view. Changing zoom levels doesn't really affect the issue.
Re: Issues in displaying manga
check Auto zoom settings
Arth
Post by Arth »
user0 wrote: Mon Aug 18, 2025 3:54 am check Auto zoom settings
I tried every single zoom option, nothing helps. The issue is not the zoom but XnView creating that white background and treating it as part of the image. Here's a comparison of the cover image
Re: Issue when displaying manga images
Can you post an example manga file?
Arth
Post by Arth »
cday wrote: Mon Aug 18, 2025 11:34 am Can you post an example file to test?
I don't know, a tome is 445mb. Btw, I also checked a different pdf reader - Sumatra, and it also displays everything properly, just like Acrobat. Also, I should probably mention that I'm using Ghostscript (10.05.1) for pdf support.
maybe Lock zoom is enabled
also, resetting all settings by renaming xnview.ini file may help
upd: it could be this issue (fixed in 1.9.9)
