Crashes on video
olmaverick
Crashes on video
Post by olmaverick »
Hi, I've been trying to track down an issue that's been affecting me for a few weeks now, trying to click on a video crashes XnViewMP.
  • type of video doens't seem to matter, I've tried mp4, webm and mkv and all are affected
  • I've tried purging my cache and it doesn't seem to matter
  • autoplay or loop options don't seem to change anything
  • both flatpak and appimage versions are affected, at least (as those are the only ones I can easily try)
  • versions from current back to at least 1.88 are affected, which makes me think this may be something in xnview that was affected by a system update, as it was at least playing video up to a month ago or so.
  • OS: Fedora Kinoite(Silverblue) 42
  • Other tools (gwenview, smplayer, vlc, etc.) seem to be unaffected.
When I use the flatpak version, it crashes with no error message; the AppImage crashes with the error:
/tmp/.mount_XnViewGopDMJ/usr/bin//xnviewmp: line 5: 57943 Segmentation fault      (core dumped) "$usr/XnView/XnView" "$@"
Any suggestions/ideas for other things I can try?
Re: Crashes on video
please try to start xnview from a terminal to see logs
olmaverick
I did that, but the only useful output when it crashed was the single line that I put in the post above. Here's what seems to be the point when it loads a video to the point where it crashes:
### ThumbLoaderThread :: setFirstItemToLoad
 ** start condition wake one 3
### ThumbLoaderThread :: setFirstItemToLoad ok
######### CategoryModel :: checkAndSave()
MyView::set LOAD FULL /var/home/mav/Nextcloud/MEEMS/JIFS/supernatural-spn.mp4
BitmapLoadThread :: stop()
## MyView::onLoaded </var/home/mav/Nextcloud/MEEMS/JIFS/supernatural-spn.mp4> </var/home/mav/Nextcloud/MEEMS/JIFS/supernatural-spn.mp4> </var/home/mav/Nextcloud/MEEMS/JIFS/supernatural-spn.mp4> (0)
## MyView::onLoaded ok
@@ BitmapResizeThread:: clear
######ThumbLoaderThread :: forever 2 : 3e7f9630
CHECK <0>
######ThumbLoaderThread :: forever : 3e7f9630
 ** start condition wait
MyView::change /var/home/mav/Nextcloud/MEEMS/JIFS/supernatural-spn.mp4
OPEN player /var/home/mav/Nextcloud/MEEMS/JIFS/supernatural-spn.mp4
X11 display: 0x3e4889e0
QMDKWidget setMedia /var/home/mav/Nextcloud/MEEMS/JIFS/supernatural-spn.mp4
############################################ InfoPropertiesView
resizeGL>>>>>dpr: 2.000000, logical dpi: (96.000000,96.000000), phy dpi: (129.615947,129.702128)
###  checkChanged : 1
/tmp/.mount_XnViewEnokjd/usr/bin//xnviewmp: line 5: 162602 Segmentation fault      (core dumped) "$usr/XnView/XnView" "$@"
It says it's dumping core but I'm not sure where it's putting the dump, it doesn't seem to be in /tmp or in my home directory.
i've tried on a clean Fedora 42, and no problem to play mp4 files
Please change debug=2 in your xnview.ini
BlackOverlord
Post by BlackOverlord »
I have the same issue on Bazzite. The app crashes whenever I select a video file in the file browser (apparently it tries to load a preview)
OS version: Bazzite 42.20250908
App version: XnView MP 1.9.3 (flatpak version)
Logs are attached (with debug=2 in the config)
Here is a core dump: https://mega.nz/file/w4MDDaCB#JADp2ed36 ... dI-PbJvvns
I hope this helps fixing the issue
olmaverick
I set debugging on as requested and here is the output. I also have a core dump for this same crash if it would be helpful.
olmaverick wrote: Fri Sep 12, 2025 4:53 pm I set debugging on as requested and here is the output. I also have a core dump for this same crash if it would be helpful.
Thanks, the output txt seems to be incomplete?
olmaverick
I'll try again.
Try to set
QT_XCB_GL_INTEGRATION=xcb_egl
olmaverick
I set that environment variable and tried the standalone binary version again, but it still crashes. Output attached.
dandv
Post by dandv »
v1.9.4 crashing as well on Ubuntu 25.04, KDE Plasma 6.3.4, Wayland.
Intel® Iris® Xe Graphics & NVIDIA GeForce RTX 3050 Ti Laptop GPU
$ QT_XCB_GL_INTEGRATION=xcb_egl ./XnView_MP_1.9.4.AppImage
0.33.1 (git 8da6cdd) - Multimedia Development Kit. Copyright (c) 2016-2025 WangBin(QtAV author) <wbsecg1 at gmail.com>
Build for: ubuntu/25.04 4KB x86_64; glibc2.24/2.41 libc++210000; Clang21.0.0 (++20250702083737+272576543246-1~exp1~20250702203908.1008); 15:48:47 Jul 5 2025.
==> 2.000000 2.000000 151.218605 96.000000 (1)
XNVIEW restoreGeometry before : 640 480
XNVIEW restoreGeometry after : 1594 984
ARG[] = /tmp/.mount_XnViewMOEJjM/usr/XnView/XnView
QObject::connect: No such signal InfoPropertiesView::itemDoubleClicked(QTreeWidgetItem*,int)
QCssParser::parseColorValue: Specified color without alpha value but alpha given: 'rgb 0, 0, 0, 127'
QCssParser::parseColorValue: Specified color without alpha value but alpha given: 'rgb 255, 255, 255, 255'
BookmarkNode::BookmarkNode : 0x36d98cf0
TAGS : 168
: 168
BLOB length 75
BLOB length 75
BLOB length 75
BLOB length 75
BLOB length 75
BLOB length 75
BLOB length 75
BLOB length 75
BLOB length 75
BLOB length 75
BLOB length 75
BLOB length 75
BLOB length 75
BLOB length 75
BLOB length 75
BLOB length 75
## onItemPressed
#### onCurrentChanged 27
## BaseViewWindow :: ~BaseViewWindow()
QMutex: destroying locked mutex
## BaseViewWindow :: ~BaseViewWindow() ok
X11 display: 0x36a3ec40
QMDKWidget setMedia /media/dandv/SD_Card/DCIM/DJI_001/DJI_20251012235820_0046_D.MP4
resizeGL>>>>>dpr: 2.000000, logical dpi: (96.000000,96.000000), phy dpi: (151.218605,151.218605)
I posted a related thread in July 2024: Crash when opening any DJI drone MP4 file
wairu
Post by wairu »
I think you're not alone with this as I experienced the very same symptoms.
I changed the debug parameter in ~/.config/xnviewmp/xnview.ini as instructed above by others, and fed the output into a logfile, which I just attached here.
At line 324 where it loads the .webm video, it gave me a clue at line 434 where it tried to load X11 display, to no avail, because I'm running on Wayland Plasma, specifically on CachyOS.
Let me summarize my config:
  • OS: CachyOS
  • DE: Plasma 6.5.4
  • Kernel: Linux 6.18.2-3-cachyos
  • CPU: MD Ryzen 9 7900X (24) @ 5.74 GHz
  • GPU: NVIDIA GeForce RTX 4070 Ti [Discrete]
  • ffmpeg: n8.0.1 - built with gcc 15.2.1 (GCC) 20251112
Downloaded .tar.gz version, extracted, ran it, focused on video files in XnView Filebrowser: Crash
Downloaded AUR version, focused on video files in XnView Filebrowser: Crash
This does not alone happen with .webm, but with any other video file.
The dilemma: Since X11 is being passively-, but surely rolled out in the future to be exchanged by Wayland, what would be the preferred practice to avert this issue?
biley
Post by biley »
I have also been getting crashes on video with the last few versions. The last version that had working videos for me was 1.9.2
I have attached logs of version 1.9.10 where I get crashes on video (the audio plays but the visuals don't);
and logs from 1.9.2 where playing video is (mostly) fine.
I also want to thank the developers. This is the best image viewer I've used most of the time I prefer using version 1.9.2 to view video over vlc.
Edit: I'm using Arch linux with KDE.
biley wrote: Thu Feb 19, 2026 6:09 am I have also been getting crashes on video with the last few versions. The last version that had working videos for me was 1.9.2
you can always reproduce with mp4?
biley
Post by biley »
xnview wrote: Thu Feb 19, 2026 6:44 am
Yes I can always reproduce. I have attached another log of 1.9.10 showing a crash with a different mp4 if that helps.
I install xnviewmp using the AUR.
Please let me know if you would like me to test anything.
