1.9.3: Manually assigned icons are not visible on the toolbar.
adrem85
Post by adrem85 »
I manually assigned my icons to some commands on the toolbar, and they became visible in the Settings. But they did not appear on the toolbar itself - there is still only text there. Windows 11.
XnViewMP_Toolbar icons not appear.mp4
Re: 1.9.3: Manually assigned icons are not visible on the toolbar.
do you have used png for custom icon?
xnview wrote: Wed Aug 27, 2025 6:04 am do you have used png for custom icon?
only png works
ico, icns, exe, dll - do not work
adrem85
Post by adrem85 »
Thanks for the clarification, the problem is solved.
