1.9.3 (Linux-AppImage) doesn't run on OpenSuSE Tumbleweed
michael_
Post by michael_ »
first thanks for this cool piece of software!!!
But the newest version AppImage doesn't run on OpenSuSE Tumbleweed, version 1.88 AppImage did. The downloaded tgz of 1.9.3 also runs.
Starting 1.9.3-AppImage with mouseclick from desktop doesn't work, starting from Konsole doesn't work too and shows the error:
/tmp/.mount_XnViewbaFpkc/usr/XnView/XnView: /lib64/libnsl.so.1: version `GLIBC_2.2.5' not found (required by /tmp/.mount_XnViewbaFpkc/lib/x86_64-linux-gnu/libwrap.so.0)
The installed version of glibc is 2.4.1, should be o.k. Copying the available version of libnsl to libnsl.so.1 of course doesn't help
Maybe someone wants to fix the problem.
Thank you. Bye.
Michael
Re: 1.9.3 (Linux-AppImage) doesn't run on OpenSuSE Tumbleweed
you need to install libnsl1
michael_
Post by michael_ »
Hello, libnsl1 is installed. But not with the old version, xnview wants, but with the actual version.
i dont know why appimage needs libnsl1
michael_
Post by michael_ »
Maybe you can ask somebody who knows???
Or what do you suggest to solve the problem?
michael_ wrote: Fri Sep 05, 2025 10:59 am Or what do you suggest to solve the problem?
you can use the TGZ package
michael_
Post by michael_ »
that's what i do. But that doesn't correct the error!
vyrgozunqk
Post by vyrgozunqk »
The issue is that libnsl.so.1 is part of glibc up to glibc-2.38, while Tumbleweed (and the other rolling distros) switched to glibc-2.41+
I've tried symlinking the newer version libnsl.so.3, but it crashes due to the much newer glibc.
/lib64/libnsl.so.1: version `GLIBC_2.2.5' not found (required by /tmp/.mount_xnviewpJglha/lib/x86_64-linux-gnu/libwrap.so.0)
Recompilation against newer toolchain is needed in this case.
