Currently when a file is loaded, XnView checks always if there is file.xm or file.ext.xmp
Should this be according to the activation of the 'Create or update XMP sidecar' setting?
Re: 'Create or update XMP sidecar' setting
nope
I think it should stay like this:
On the other hand, I would probably merge these 2 settings tabs somehow as sidecar is a subset of companion files
- read (Settings > Companion files)
* -- {ext}.xmp;xmp in Association list
- write (Settings > Metadata > Sidecar)
'Create or update XMP sidecar' checkbox
jkm
No, "creating or updating" a sidecar file should be a separate option.xnview wrote: Sun Aug 31, 2025 1:39 pm Currently when a file is loaded, XnView checks always if there is file.xm or file.ext.xmp
You said it "ALWAYS" checks.
When opening a file, It should only check (and then read the XMP) if the IMPORT options are checked on the Metadata page.
It should only write the file if "Create or update XMP sidecar" is checked.
As for the companion file settings, it only needs to check and process the XMP if the master file is deleted, moved, or renamed.
