In SIMILAR IMAGE CONTENT allow image A and image B in the same view box and be able to alternate them
xpunisherx
Post by xpunisherx »
In SIMILAR IMAGE CONTENT:
Add an option to compare similar images. In the preview, one image can be overlaid on top of another to better compare differences and similarities between similar images found. You can also alternate between images (image A and image B in the same view box, allowing you to alternate between them).
reference image: https://prnt.sc/eqafo_SaDDNs
https://imgur.com/6eM9QuN
laneAr
Re: In SIMILAR IMAGE CONTENT allow image A and image B in the same view box and be able to alternate them
Post by laneAr »
like DuplicateCleaner ? it does easier to compare the difference between similar images. hope they will add this
