I have draw selection box for zoom disabled and unbind (personal preference, box is distracting, i rather use zoom-in / zoom-out). When i click orange Crop icon on toolbar it opens additional crop toolbar underneath the original toolbar however no options in that additional toolbar have any effect.
Grid option does nothing
changing width / height does nothing
changing ratio does nothing
i mean it must do something because when i switch to next image it offering to save changes, however there is no visual overlay being displayed while using any tools from crop toolbar.
Crop icon on toolbar not working.
Re: Crop icon on toolbar not working.
you need to draw a selection
FKCapitalism2
Well that's the issue selection is been disabled in options as it distracting the way it works, perhaps it should give ability to draw selection after pressing the crop button, not crop on existing selection.
Sorry but what do you means?FKCapitalism2 wrote: Sat Sep 20, 2025 2:05 pm Well that's the issue selection is been disabled in options as it distracting the way it works, perhaps it should give ability to draw selection after pressing the crop button, not crop on existing selection.
FKCapitalism2
Could you make XnViewMP to go in crop mode independent from other settings so it does either use existing selection box or if there's no selection box it make one 100%x100% over existing image and let you resize it. sort of how photoshop works.
