FIles with same name but different extension only 1 shows
HankH
Post by HankH »
With these 2 files only the DNG shows up in the browser. The JPG will show up if I rename it. The files are from a DJI drone and the linux FILE command output is shown below. DNG is ~25MB JPG is ~5MB in size.
Should they not both show up in the browser? I'd attach but they are too big.
file 20250804_213632.DNG
20250804_213632.DNG: TIFF image data, little-endian, direntries=42, height=128, bps=1490, compression=JPEG, PhotometricInterpretation=YCbCr, manufacturer=0\031`$\220\031`%0\031\360$`\032`$`\031`&`\031, model=FC2103, orientation=upper-left, width=160
20250804_213632.JPG: JPEG image data, Exif standard: [TIFF image data, little-endian, direntries=14, description=created by dji camera, manufacturer=\275\343\222\332HJ0\217\034\272\204\310\313\310\312\301\337.\023|\2023 Q\033F\252\201\207\226\330yE\313W\017\022\264\221\250\334\305z;\204\225U\243\302\2343!,\030\027\331\273<\222\252\350\215\212\250\356\323z\307\335Kv\2756\377, model=FC2103, orientation=upper-left, xresolution=886, yresolution=894, resolutionunit=2, software=10.00.14.05, datetime=2025:08:04 21:36:32, GPS-Data], baseline, precision 8, 4056x3040, components 3
Re: FIles with same name but different extension only 1 shows
Settings>Companion files - show companion files
