In Win 10, everything was simple and perfect: I specified the thumb-size in the settings, and the thumbs hat exactly this size, crisp and sharp.
Now I moved to Win 11, and I spent around 45 min trying to get the same thumbnail-size as before. It should be easy, because I could duplicate all my settings. However, the thumbnails were much too small. I confirmed with with screenshot & measuring. I can change the size with a slider at the bottom, but it seems impossible to adjust it to get the specified size exactly.
I even tried playing with the Windows high-dip-settings for the app, no change.
So, how is it possible to simply get my thumbnails exactly 160 x 160 px, as before, crisp and sharp? I never want them smaller or bigger. Just 160 x 160. That's why I specified the size. Shouldn't that be possible AND simple? Is it windows's fault? Nevertheless, I'd like a solution.
Win 11: I fail to get the desired thumbnail-size [SOLVED]
paul_sch
Re: Win 11: I fail to get the desired thumbnail-size
there is an issue with hidpi scaling:
1.9.1 - browser - thumbnails - fix scaling
however, it does not affect thumbnails quality:
XnViewMP - thumbnails - understanding quality/size
paul_sch
Thanks. Seems quite complicated. So far, I fail to get the desired size/scale.
Concerning quality: Unnecessary scaling always affects quality, even if the image is scaled down from a slightly larger image. I see the difference quite clearly. That's why it's important for me to see the thumb 1:1...
paul_sch
This issue has been solved by another thread: https://newsgroup.xnview.com/viewtopic.php?t=49630
In short: In the "normal" menu bar (NOT the settings): View -> Thumbnails size -> Custom
