Batch rename: include shuttercount in filename
Blue_Nature
Post by Blue_Nature »
I would like to include shuttercount in filename batch rename.
Anyone any idea how to do that?
I am using Nikon NEF raw format
Thank you for your consideration
jkm
Re: batch rename. I would like to include shuttercount in filename
Post by jkm »
XnViewMP is not capable of this.
But you can use Advanced Renamer instead, to include Nikon's ShutterCount tag in the rename.
https://www.advancedrenamer.com/
I hope this helps...
Blue_Nature
Re: Batch rename: include shuttercount in filename
Thanks Jkm,
I'll have a look.
Blue_Nature
Yes this works.
I used in the renaming method the following expression: Z8-<ExifTool:Shuttercount>
And this works.
Thanks again.
jkm
Post by jkm »
Good. I have hopes that XnViewMP can be enhanced to support better EXIF tags in the future, both in the app and as part of renaming like you're doing here.
