(solved) .deb bug for Debian 13 (trixie) and MX Linux 25
oops66
Post by oops66 »
Hello Pierre,
I have a bug with XnViewMP. because the libgdk-pixbuf2.0-0 library changed it's name but its still available, its libgdk-pixbuf-2.0-0 now. they XnView will need to change their debian control file.
(from here: https://forum.mxlinux.org/viewtopic.php ... 90#p833090 )
keep your good job, xnview still a must have.
Regards oops66.
Re: .deb bug for Debian 13 (trixie) and MX Linux 25
you can force the installation
oops66
Post by oops66 »
xnview wrote: Sun Sep 28, 2025 7:21 am you can force the installation
It is true, by this way that's work. xnview can works.
root@mx25:/home/tof-mx# dpkg -i --force-overwrite /folder1/XnViewMP-linux-x64_V1.9.3.deb
Merci Pierre.
oops66
Post by oops66 »
oops66 wrote: Sun Sep 28, 2025 6:51 pm
Merci Pierre.
Edit, it is not a real solution, I have to do in this case , because the system after is unstable:
apt --fix-broken install
OK thanks Pierre, the new xnview version : XnViewMP-linux-x64_V1.9.4.deb , is now ok for MX25.
It was fast ;-)
Nice.
Package: xnview
Version: 1.9.4
Architecture: amd64
Installed-Size: 18
Depends: libasound2 (>= 1.0.16), libatk1.0-0 (>= 1.12.4), libbz2-1.0, libc6 (>= 2.17), libcairo-gobject2 (>= 1.10.0), libcairo2 (>= 1.2.4), libcups2 (>= 1.4.0), libdbus-1-3 (>= 1.9.14), libdrm2 (>= 2.4.30), libegl1-mesa | libegl1, libfontconfig1 (>= 2.11), libfreetype6 (>= 2.3.5), libgcc1 (>= 1:3.4), libgdk-pixbuf2.0-0 (>= 2.22.0) | libgdk-pixbuf-2.0-0 (>= 2.22.0), libgl1-mesa-glx | libgl1, libglib2.0-0 (>= 2.33.14), libgstreamer-plugins-base1.0-0 (>= 1.0.0), libgstreamer1.0-0 (>= 1.4.0), libgtk-3-0 (>= 3.5.18), libopenal1 (>= 1.14), libpango-1.0-0 (>= 1.14.0), libpangocairo-1.0-0 (>= 1.14.0), libpulse-mainloop-glib0 (>= 0.99.1), libpulse0 (>= 0.99.4), libsqlite3-0 (>= 3.5.9), libstdc++6 (>= 5), libx11-6 (>= 2:1.4.99.1), libx11-xcb1, libxcb-shm0, libxcb1 (>= 1.8), libxcb-xinerama0, libxext6, libxfixes3, libxi6 (>= 2:1.5.99.2), libxv1, zlib1g (>= 1:1.2.3.4), libopenal1
Section: graphics
Priority: optional
Maintainer: None <[email protected]>
Homepage: http://www.xnview.com
Description: Graphic viewer, browser, converter.
