In fullview zoom does not lock position
FlyAway
Post by FlyAway »
Hi :)
I have this annoying problem, I often have to set small photos by increasing the zoom to frame a particular area of ​​it, the problem is that when I click on the arrow to move to the next photo, the zoom is memorized but not the position of the photo, so I have to reposition it myself :(
thanks
jkm
Re: in flullview zoom does not lock position
Post by jkm »
It sounds like you’re trying to compare particular areas of multiple photos.
Try using the Compare function. It will synchronize the zoom and position between multiple images and let you have them all onscreen at once or in separate tabs.
uncheck Reset X/Y position on file change (No fit) in Settings>View
FlyAway
Post by FlyAway »
user0 wrote: Mon Sep 29, 2025 5:15 am uncheck Reset X/Y position on file change (No fit) in Settings>View
Thanks!!!
