I changed a lot of settings and I don't remember which ones, but now I only see the XnViewMP icon in the systray, but nothing appears on the rest of the button. How can I make "XnView MP" or the name of the file I'm viewing appear?
Systray icon without text
FlyAway
Hi
Re: systray icon without text
Settings>Interface>Titlebar
FlyAway
Thanks, that was the first place I looked but I didn't find anything, where exactly?
Re: Systray icon without text
its {Filename With Ext} by default for Viewer, maybe you changed it to 'space'
FlyAway
thanks,user0 wrote: Mon Sep 29, 2025 3:31 pm its {Filename With Ext} by default for Viewer, maybe you changed it to 'space'
The problem is that I had set "{Filename}" with a lot of spaces in front of it because I thought it was for the top bar and I wanted to center the name.
Do you know how to make "XnViewMP" appear instead of {Filename}?
FlyAway
FlyAway wrote: Mon Sep 29, 2025 6:51 pmthanks,user0 wrote: Mon Sep 29, 2025 3:31 pm its {Filename With Ext} by default for Viewer, maybe you changed it to 'space'
Now is all ok![]()
