Add "last used" option
oayz
Post by oayz »
Basically to all menu items with long selection list:
- effects
- selection : set ratio
- selection : set size
- image : map
etc.
Would be nice to have it assignable as a keyboard shortcut (I used "set ratio" all the time)
Thanks!
Re: Add "last used" option
you already can restore previously saved selection
oayz
Post by oayz »
Indeed, thanks for the reminder, and it's assignable to shortcuts
Now need the same for ratio
