1. Open DNG image in full screen
2. Then open with Photoshop using Open With menu and edit then save and close
provided embed full size preview enabled in Adobe Camera Raw it will update embedded preview inside DNG file
3. Go back to to thumbnail view
4. Open DNG full screen again
Preview image is not being updated.
Preview only updates once close XnView MP and open again.
I understand XnView MP caching files in memory, is there way to make cache check timestamp of files on HDD, if timestamp on HDD newer than one in cache then then force re-load that file?
Need to restart XnView MP after updating DNG preview
FKCapitalism2
Nzumita
Re: Need to restart XnView MP after updating DNG preview.
Same problem. I would appreciate any help!
if you select another file, and go back to DNG file, open it, it works?
FKCapitalism2
Yes, but not sure if going back and forth just one file or several files is required.xnview wrote: Wed Oct 22, 2025 8:53 am if you select another file, and go back to DNG file, open it, it works?
Sometimes however even going to thumbnails then full screen and rotating several files back does not update view.
if you disable settings>View>Keep current image/one image ahead?
FKCapitalism2
Noxnview wrote: Mon Oct 27, 2025 7:10 am if you disable settings>View>Keep current image/one image ahead?
Currently takes 3 images ahead or back to until DNG preview updated
Strange, even if you restart XnView?FKCapitalism2 wrote: Thu Oct 30, 2025 12:01 pm Currently takes 3 images ahead or back to until DNG preview updated
FKCapitalism2
If i restart xnviewmp shows updated preview when instantly when loaded.xnview wrote: Tue Nov 04, 2025 10:06 amStrange, even if you restart XnView?FKCapitalism2 wrote: Thu Oct 30, 2025 12:01 pm Currently takes 3 images ahead or back to until DNG preview updated
I have following settings now. Actually checked again, with above settings only need to switch one image ahead and back to get updated preview.
