Ghostscript
Group for those who want to contribute to the Help file
Moderators: xnview, Ty
Ghostscript
Ghostscript is open-source software which enables XnView and related programs to load PostScript-based file formats (PS + EPS + AI) as well as PDF for display, printing, and conversion.
Ghostscript has to be downloaded and installed separately.
Download
XnView Classic as well as the 32-bit editions of XnView MP, XnConvert, NConvert, and XnShell require Ghostscript 32-bit to be installed (even on 64-bit operating systems), while all 64-bit versions need Ghostscript 64-bit.
Users of XnView Classic who run into trouble getting A<u>G</u>PL Ghostscript v9 to work are advised to give A<u>F</u>PL Ghostscript v8 (gs854w32.exe) a try.
Installation
Tutorials:
Configuration
How to activate thumbnails for PostScript files in XnView's browser and shell extension:
XnView Classic
Tools → Options... → File List → File List → AI, PS, PDF files → Show item in view 'Thumbnails'
XnView MP
Tools → Settings... → File list → Custom filter → AI/PS/PDF → Show as Thumbnail
XnShell
Options... → No thumbnail for EPS/PDF
By default, Ghostscript loads images with a resolution of 72 dots per inch (DPI).
This value can be customized:
XnView Classic
Tools → Options... → Read/Write → Read → EPS/PS/AI/PDF
XnView MP
Viewer/Editor: File → Format settings... → Read → PS/PDF
Tools → Batch convert... → Settings → Load format settings... → PS/PDF
XnConvert
References
imagoiq
Re: Ghostscript
Post by imagoiq »
For macOS with Homebrew install, I had to symlink the install to work (not mentioned in the wiki of Scribus) even if the `gs` command was available.
sudo ln -s /opt/homebrew/bin/gs /usr/local/bin/gs
