Browser - catalog filter - add Square orientation, fix sorting
XnViewMP 1.9.5
  • Orientation
    - add Square option (see CaptureOne)
  • Sorting
    - make sorting case insensitive
Example
  • Orientation - square option
Related
Re: Browser - catalog filter - add Square orientation, fix sorting
What is 'Square orientation', could you post an example?
And maybe an example image displayed in Landscape, Portrait and Square orientations, if that makes sense.
Edit:
I think perhaps the issue here is whether the word 'Orientation' is the appropriate word, you mean the shape of the rectangle containing the thumbnail?
This problem is supposed to be fixed in XnView MP 1.9.6. Please check and confirm the bug fix here.
done in 196
