In XnView MP, Info panels, EXIF tab, the display of the ‘Image description’ field is limited to 2,048 characters. The following image has an entry with 3,794 characters.
Note: Downloading will result in a reduced image! I can provide the original.
Galerie: https://www.krasna-photo-collection.de/ ... &slide=167
Detail: https://www.krasna-photo-collection.de/ ... ge-074.jpg
Piwigo: https://pw.krasna-photo-collection.de/p ... tegory/168
I learned my working method 12 years ago from an expert. He wrote his findings in his images as EXIF data.
My request: Increase the size of the ‘Image description’ field in the Info panels, EXIF tab display to 4 kB.
Increase the size of the ‘Image description’ field display to 4 kB.
Otto_Riehl
Otto_Riehl
Otto_Riehl
Re: Increase the size of the ‘Image description’ field display to 4 kB.
Addition to my request:
IPTC:Caption-Abstract is limited to 2000 characters in the IPTC/IM specifications.
EXIF:Image Description and XML:Description are not directly limited.
The total amount of EXIF data in a JPEG image is limited to 64 KB. Data larger than 64 KB can only be written to a sidecar file.
Metadata > Edit IPTC... only allows 2 KB of data – OK.
Metadata > Edit XML... allows more than 3.7 KB of data (I have not tested the maximum) – OK.
My sample file has 3747 characters in the description.
Sample file:
https://www.swisstransfer.com/d/663d509 ... afca2219a9
Screenshots
new 29.10. -15:36 https://www.swisstransfer.com/d/915fdea ... c553c6fced
The info area in XnView MP shows:
Image view > Information > {EXIF:Image Description} displays 1024 characters. I would like to see a larger display here (4 KiB).
Sample file:
Screenshots
- EXIF displays 2049 characters in a larger field. I would like to see a larger display (4 KiB) here.
- IPTC-IIM displays 2030 characters in one line. Copy value only returns a subset.
- XML displays 259 characters in one line. Copy value only returns a subset.
- Exiftool displays in one line
- EXIF:Image Description 3747 characters. OK
- XML:Description 3747 characters. OK
- IPTC:Caption-Abstract 1995 characters. OK
