Close all XNView instances
klumy
Post by klumy »
such a command would be really useful
XNView 1.91.5
Windows XP SP3
Re: Close all XNView instances
klumy wrote:such a command would be really useful
Hmm, do you work with so many XnView instances? Is one instance with folder tabs not sufficient?
I've never felt a need for something like "Close all XnView instances" (in contrary, there should be something like "Browse" in the folder tree to open a new XnView instance with a specific folder).
klumy
Post by klumy »
you are right, I forgot the option "just allow one instance" in this case all images will be opened in one instance.
:D
XNView 1.91.5
Windows XP SP3
