Post
by user0 »
XnViewMP 1.9.5
Windows11 (25H2), display resolution 3840x2160, dpi scale 150%
Settings - Integration
its only possible to enable XnShell during installation process, which is inconvenient
- add 'Enable XnShell' checkbox
which will
- register
regsvr32 /s "<path_to_app_folder>\XnViewShellExt64.dll"
- unregister
regsvr32 /s /u "<path_to_app_folder>\XnViewShellExt64.dll"
Example
- ACDSee PicaView
- other_apps_acdsee_picaview.png (17.28 KiB) Viewed 285 times
Related
user0 on Fri Nov 21, 2025 2:17 pm, edited 1 time in total.
Post
by xnview »
Thanks to your detailed description I can reproduce
the problem.
Post
by xnview »
This problem is supposed to be fixed in
XnView MP 1.9.6. Please check and confirm the bug fix here.
Post
by user0 »
done in 196
