Can place holders be combined or stacked? I tested these via the TEXT action on xnconvert
DoubleD
Post by DoubleD »
so I have the following directory {Directory}
  • C:\Users\Domenic\Pictures\~ MAC & USBANDS\~ USBands\2025\2025-10-25 Southington High School\00 Joseph A. DePaolo Middle School
I want to remove "C:\Users\Domenic\Pictures\~ MAC & USBANDS\~ USBands\2025\2025-10-25" and "\00 Joseph A. DePaolo Middle School" so that I am left with just "Southington High School"
I can use {Directory[69-]} to get "Southington High School\00 Joseph A. DePaolo Middle School" but how do I strip out "\00 Joseph A. DePaolo Middle School"
I see that {Folder name} has "00 Joseph A. DePaolo Middle School" so I was hoping that {Directory[69-][~\{Folder name}~]} would do it but it does not all I get is "Directory[69-][~\00 Joseph A. DePaolo Middle School~]}"
I also tried {Folder name[~Joseph~Joe]} and I would think that would print "00 Joe A. DePaolo Middle School" but it doesn't print anything so I'm not sure I am using the word replace feature correctly
    • • {Filename} => img_example_105
      You can replace a word by another by using [~xxx~xxx]
      eg.
      • {Filename [~img~out]} => out_example_105
Re: Can place holders be combined or stacked? I tested these via the TEXT action on xnconvert
Currently no way, but perhaps [regexp] will be good to add
