I installed Ubuntu 19.04 today and encountered a problem: XnView won't start. It doesn't matter whether I try to launch it from the UI or the terminal. Any ideas?
XnViewMP wont start in Ubuntu 19.04
Re: XnViewMP wont start in Ubuntu 19.04
if you start it in a terminal?
Margeb
similar problem here in Mint LMDE6 and Cinnamon 6.4.8.
Sometimes MP does not start or very slow and hangs with a black screen.
Output from terminal:
Any hints?
Markus
0.33.1 (git 8da6cdd) - Multimedia Development Kit. Copyright (c) 2016-2025 WangBin(QtAV author) <wbsecg1 at gmail.com>
Build for: linuxmint/6 4KB x86_64; glibc2.24/2.36 libc++210000; Clang21.0.0 (++20250702083737+272576543246-1~exp1~20250702203908.1008); 15:48:47 Jul 5 2025.
qt5ct: using qt5ct plugin
==> 1,000000 1,000000 90,158498 96,000000 (0)
XNVIEW restoreGeometry before : 640 480
XNVIEW restoreGeometry after : 1680 988
ARG[] = /opt/XnView/XnView
QObject::connect: No such signal InfoPropertiesView::itemDoubleClicked(QTreeWidgetItem*,int)
QCssParser::parseColorValue: Specified color without alpha value but alpha given: 'rgb 255, 255, 255, 178'
QCssParser::parseColorValue: Specified color without alpha value but alpha given: 'rgb 0, 0, 0, 255'Markus
