XnView: MP 1.9.5 - 64 bit
OS: Windows 64bit
Passing a folder is not working if it's in the following format: "C:\Some folder\"
Effect: "File not found!" error shown
1. Run xnviewmp.exe from a command line and pass a valid folder as a parameter that ends with a backslash and has quotes around it, e.g.
xnviewmp.exe "C:\Some folder with spaces and a trailing backslash\"
Actual: XnViewMP shows an error "File not found!"
Expected: XnViewMP opens the folder
Additional notes:
- If I pass a folder without a trailing backslash, it works.
- If I pass a folder with a trailing backslash but without quotes, it also works.
1.9.5: XnViewMP doesn't open a passed folder if it has a trailing backslash and quotes
Infi220
Re: 1.9.5: XnViewMP doesn't open a passed folder if it has a trailing backslash and quotes
you can reproduce each time? It works correctly if i use xnviewmp "c:\folder\"
Infi220
Actually, I tested it further and it turned out to be an unrelated issue. Not a bug in XnViewMP. My apologies.
