New Affinity version, with new file format
lphilpot
Post by lphilpot »
In March of last year Canva acquired Serif and their products: Affinity Photo, Designer and Publisher. XnView supports the embedded preview thumbnail images in .afphoto files (from Affinity Photo 2), but now Canva has released Affinity 3 which replaces all three Serif Affinity apps. The new file format has an "af" extension and we only get icons in XnView with no metadata:
Those are the new and old versions of the same file.
I understand it'll take a while to support the new format, I just wanted to mention it. I have no idea how / where to get enough specs to implement reading these files enough for XnView's uses.
Len Philpot
M1000
Re: New Affinity version, with new file format
Post by M1000 »
I don't think there has changed a lot under the hood, since if you rename the .af file to .afphoto, XnView is still able to show the embedded preview thumbnail.
lphilpot
Post by lphilpot »
Well, that should hopefully make it simpler to implement thumbnail support. I've added 'af' to my custom extensions list, but it doesn't change preview or not.
Camva claimed the new format was not backward compatible. Renaming *.af *.afphoto has no impact on loading the file in Affinity, either. Apparently the app must be reading the internal file header to determine its format, not relying on the extension.
Len Philpot
paleolith
Post by paleolith »
Have a look here:
viewtopic.php?p=209818
lphilpot
Post by lphilpot »
Yep, I already submitted a sample file.
Len Philpot
brettkan
Post by brettkan »
Any progress for support of Affinity V3 files? I notice that Windows 11 Explorer can view the thumbs, but XnView cannot. Is it just me, or has support not been enabled yet?
lphilpot
Post by lphilpot »
On Windows 11 I see v3 thumbnails and small-ish preview images, but that's it. Is there something more you need to do?
Len Philpot
laurent45654
Post by laurent45654 »
On macOS I'm only seeing the file icon. Is there something that needs to be done to enable thumbnails for .af files?
