Lossy DNG displayed improperly
pulancho
I verified that the same problem with 1.9.5 is on MacOS 15.7.2 and Windows 11.
XnView MP displays only a 256x192 pixel Lossy DNG image when I open it up. XnView MP properly displays a Lossless DNG.
Both DNG files created with Photoshop 2025.
Re: Lossy DNG displayed improperly
change View from 'Embedded preview' to 'Full size'
in Settings > Read > Camera RAW
pulancho
Thank you for the reply.
The embedded JPEG is 5220x3912 pixels.
But I did as you suggested. There is no change. Still just 256x192.
reload image
if does not help - share your image
pulancho
After making the change I restarted XnView MP.
And as I wrote above a Lossless DNG is displayed properly.
pulancho
I can provide 2 DNG files created by Photoshop 2025:
1. Lossy DNG 8.2mb
2. Lossless DNG 23.4mb
What would be a good way to provide them?
1. Lossy DNG 8.2mb
Normally by providing a download link, which can be from a Google Drive account provided the download is set to be available to anyone, or maybe if size permits, as an email attachment to the xnview.com contact address on the website home page, with this topic title quoted in the subject line.
pulancho
I hope this works.
1. Lossy DNG 8.2mb
https://drive.google.com/file/d/1nVWUT ... sp=sharing
https://drive.google.com/file/d/1jKMW3D ... sp=sharing
1. Lossy DNG 8.2mb
pulancho
I provided the 2 DNG files as was requested. Can you get them? No comments?
your links require Access request
change share option from 'Restricted' to 'Anyone with the link'
pulancho
Okay, I changed them to Anyone with the link. I hope it works this time.
so far only adobe apps can open your OM124428_lossy_full.dng correctly
I have not found any app that can open it in full size
pulancho
Thank you for verifying that XnView MP does not display it properly. That is why I reported this problem here. I hope a future version will work correctly.
pulancho
I discovered that the standard Mac Preview app properly displays the lossy DNG. I hope this bug in XnView MP will get fixed.
mudo_j
This is not a bug, it is an unsupported proprietary format. No open-source raw editor can open it.
