The import window keeps shrinking
Dmytro42
Post by Dmytro42 »
I’m importing a huge number of photos, and many of them are duplicates, often appearing one after another.
A dialog window appears on the screen where I can choose “Skip” or another option. When I click “Skip,” the dialog window becomes smaller — it shrinks by about 5–10 pixels.
If you only have a few photos in a row, you won’t notice it. But if you have hundreds or thousands of identical photos, after about 20 prompts, the dialog window becomes extremely narrow, making it impossible to see the photo properly.
After that, the window stops shrinking but starts moving downward, going beyond the visible area of the Windows 11 screen.
I hope I’ve described the problem in enough detail.
Re: The import window keeps shrinking
you talk about the 'Replace' dialog?
