Text alignment breaks when “Outline” is enabled in XnConvert 1.106.0 (Linux Mint)
Luigi
Post by Luigi »
I’m reporting a small issue that might help reproduce a text alignment bug in XnConvert.
I’m using XnConvert 1.106.0 - un*x x64 (Oct 12 2025) - Libformat 7.228 on Linux Mint.
Text alignment (Left / Center / Right) works correctly unless the “Outline” option is enabled.
When outline is active, the alignment no longer works — text shifts to a default or random position.
Steps to reproduce:
Add a Text action.
Set alignment to Left (or Right).
Enable the “Outline” option.
Preview or convert an image — alignment fails.
Disabling the outline restores correct alignment.
It seems that the text bounding box isn’t recalculated when the stroke is drawn.
Thanks for checking this issue,
Luigi
Re: Text alignment breaks when “Outline” is enabled in XnConvert 1.106.0 (Linux Mint)
This problem is supposed to be fixed in XnView MP 1.11.4. Please check and confirm the bug fix here.
