Select/Copy/Drag Selection/Paste tool on a same image
josedumoretzsohn
In XNVIEWMP 1.9.5, despite the correction of the Select/Copy/Drag/Paste tool on a same image, which is working fine. If we press Undo, however, the selection frame disappears, unlike it happens in 1.9.3, which allows us not to lose the exact piece selected before.
josedumoretzsohn
Re: Select/Copy/Drag Selection/Paste tool on a same image
Sorry for my delayed answer. In 1.9.8 we can get the same good cleaning result. However, if we select, i.e., a slightly darker or lighter piece, I cannot redo the move with the same selection frame, because the pasting (Ctrl+V) operation clears it away, forcing us to loose the exact place and size of it. The great advantage of 1.9.3 is that it keeps the selection frame active all the time, so we do not worry with loosing its place and size. Attached photos of the operation in 1.9.3 follow.
In 1.9.8, dont click outside, you can make another Ctrl+V. Else change in xnview.inijosedumoretzsohn wrote: Wed Jan 07, 2026 1:47 am Sorry for my delayed answer. In 1.9.8 we can get the same good cleaning result. However, if we select, i.e., a slightly darker or lighter piece, I cannot redo the move with the same selection frame, because the pasting (Ctrl+V) operation clears it away, forcing us to loose the exact place and size of it. The great advantage of 1.9.3 is that it keeps the selection frame active all the time, so we do not worry with loosing its place and size. Attached photos of the operation in 1.9.3 follow.
pasteOldMethod=true
