File -> Import and sort
bondik
Post by bondik »
Hi All,
Two questions about File -> Import and sort menu command.
- Does it create a copy while importing into a new folder/catalog structure or moves the files from the source?
- If using a Subfolder with [Y/m] mask for Import and sort, what date it uses? Is it original EXIF date of a photo creation or the last modification file date?
Thank you!
Re: File -> Import and sort
bondik wrote: Fri Nov 21, 2025 9:41 pm - Does it create a copy while importing into a new folder/catalog structure or moves the files from the source?
You have a 'move files' setting
EXIF date modified
