Is there a way to avoid draw mode to be close with ESC
Yunion
Hello Im facing a problem with draw mode, if a press ESC accidentally the draw closes without warning and I lose all the edition I have made so far. This happens to me a lot and it's very annoying, I used esc to get out from the tools Im using in the edition but if there is no tools or hit it twice its all done. Is there a way to avoid this to happened or at least a message to confirm before close
Re: Is there a way to avoid draw mode to be close with ESC
it happens because you checked 'Do not ask again' in Draw close dialog
reset it via 'Reset all confirm prompts' in Settings > General
