Using Batch Convert (CTRL+U): It would be nice if after selecting Option it remembered the last used file format. For example if using JPEG more often than 99% it would save some time without a need to click over and over again to JPEG tab. Even if I just wish to check the current JPEG Quality I have to click more times than would be necessary if the last selected format was remembered.
Related suggestion is that it would be nice if a user could save some Options as a default setting, so that he knew that whenever he doesn't change any Option he would still have his standard pre-sets. To explain in a bit: I use conversion JPEG 80% on most occasions, but rarely I need 65% or 60% for example but such one-off selection is remembered, so I have to check it anytime.
Batch Convert/Options suggestions
Dreamer
Re: Batch Convert/Options suggestions
It should work like this in the next version.RSC wrote:Using Batch Convert (CTRL+U): It would be nice if after selecting Option it remembered the last used file format. For example if using JPEG more often than 99% it would save some time without a need to click over and over again to JPEG tab. Even if I just wish to check the current JPEG Quality I have to click more times than would be necessary if the last selected format was remembered.
